Creates, edits or deletes a mirroring instance description string.
| mirror_name | Specifies the mirror name. |
| description | Specifies the mirror description to create or edit. |
| none |
Deletes the existing mirror description. |
N/A.
Use this command to create, edit or delete a mirroring instance description string.
The following example configures the mirror description.
configure mirror description
This command was first available in ExtremeXOS 15.3.
